Session Values not being triggered
Thread begun 9/26/2010 8:04 am by bjgarner241692 | Last modified 12/27/2010 10:47 am by bjgarner241692 | 5747 views | 18 replies |
bjgarner241692
I cannot seem to find a trigger to work for my session values. I would like them set on Submit but it is not working.
Page attached.
Dave BuchholzBeta Tester
At the top of the page (above any recordsets etc.) you are redirecting to after the database insert
$WA_redirectURL = "sequent_confirm.php";
put this code
//=Enable Sessions=============
if (!isset($_SESSION)) {
session_start();
your sessions should then be available to you to use.
bjgarner241692
Sorry, put it where?
I placed it just before my Session setup,directly after the include files at the top of the page.
I would normally place it above the database connection file i.e.
session_start();
require_once('Connections/connDB.php'); ?>
bjgarner241692
Still no luck.
Frustrating, this works fine with ASP.
You need to move the code that is creating the sessions as well and put it just below the code I gave you i.e.
session_start();
if (!session_id()) session_start();
if(isset(
$_POST["Insert_x"]))     {
$_SESSION["Installer"] = "".((isset($_POST["wInstaller"]))?$_POST["wInstaller"]:"")  ."";
if(isset(
$_SESSION["Email"] = "".((isset($_POST["wInstEmail"]))?$_POST["wInstEmail"]:"")  ."";
if(isset(
$_SESSION["City"] = "".((isset($_POST["wInstCity"]))?$_POST["wInstCity"]:"")  ."";
if(isset(
$_SESSION["Type"] = "".((isset($_POST["wStyle"]))?$_POST["wStyle"]:"")  ."";
if(isset(
$_SESSION["Owner"] = "".((isset($_POST["wOwner"]))?$_POST["wOwner"]:"")  ."";
you will also need the session start code on the page that is using the sessions.
on any page that you want to display session data, put this code at line 1:
<?php if (!session_id()) session_start();  ?>
bjgarner241692
I am still unable to do this.
With the above code in place here is what I get:
Warning: Cannot modify header information - headers already sent by (output started at ________________\sequent_noncert_Insert.php:2) in ________________\sequent_noncert_Insert.php on line 68
this means that there is out put to the page around line 2:
if you need help finding the problem, please send a copy of the page in a zip archive.
bjgarner241692
file attached, thanks
