Error Message UE4
Thread begun 9/25/2010 7:24 pm by stprix49407889 | Last modified 9/27/2010 7:34 am by Jason Byrnes | 1152 views | 1 replies |
stprix49407889
Error Message UE4
I have installed in my hosting account PHP Pear Package Mail Extension which includes Mail, auto_SASL, Net_SMTP, Net_Socket. I have created a contact form and I got error messages, so I download the patch file and updated the file.
But still getting error message:
Warning: require_once(/home/username/phpMail.php) [function.require-once]: failed to open stream: No such file or directory in /home/username/public_html/ChickenTwentyFive/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
Fatal error: require_once() [function.require]: Failed opening required '/home/username/phpMail.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/username/php') in /home/username/public_html/ChickenTwentyFive/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
and without indicating pear path /home/ I get the following error:
Warning: require_once(/username/phpMail.php) [function.require-once]: failed to open stream: No such file or directory in /home/username/public_html/ChickenTwentyFive/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
Fatal error: require_once() [function.require]: Failed opening required '/username/phpMail.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/username/php') in /home/username/public_html/ChickenTwentyFive/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
Appreciate your help. Thanks.
Serge
your path to pear is not correct.
the code is looking for the Mail.php file in the pear directory, make sure that you specify the proper path to the pear installation. if you do not know the proper path to pear, check with your host.
