Email Triggers
Thread begun 9/24/2010 11:28 pm by sribatchu415272 | Last modified 9/25/2010 8:02 pm by sribatchu415272 | 1370 views | 2 replies |
sribatchu415272
Email Triggers
I was wondering how can I trigger an email only when a record insert was successful? The only trigger options I see are:
any form post, before page load, current page submit and Insert Button pressed.
Using Data Assist & Universal Email.
Please advise.
Thanks!
anonymous
One way to do it would be to create a flag variable right after your insert SQL statements and then add that parameter to the trigger of the email manually.
So in the block of your insert it looks like this:
if (Submit Pressed Trigger) {
sql inset lines;
sql insert lines;
$inserted = "yes";
I created a variable called "$inserted" before the closing bracket...
then, in your email trigger, modify it to look like this
if (SubmitPressed && $inserted == "yes") {
Email stuff here
By using the "&&" it means both conditions must validate as true and then use "==" to test equality.
Best regards,
Brian
sribatchu415272
Thanks Brian. That makes sense!
