split off registration - only two people can reg
Thread begun 9/24/2010 11:52 am by Larry321390 | Last modified 2/14/2011 6:53 am by Jason Byrnes | 6878 views | 11 replies |
Larry321390
My client wants the president and treasurer to be the only people that can register members. No public registration.
I fixed the user_login.php file so only log-in is the only option. I removed the link to register.
Now I need the two people to be able to log in and register the new members after they pay their dues.
Please guide me to where to begin.
Thanks,
Larry
have those two people login using the administrator user name and password that is set in the WA_Globlas.php file.
then add the admin access rule to the registration page:
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("users_LogIn.php");
Larry321390
"then add the admin access rule to the registration page:
PHP Code:.........."
I put the code after the the last "<?php require_once........." in users_Registration.php and users_Registration_Simple.php and loaded them to the server.
Then I added
<a href="../users_Registration.php">Register new member</a
to admin/index.php
It works just the way I wanted.
Thanks.
Larry
glad to hear it is working.
Larry321390
I tried to do this again on a new site. However, when go from the Admin index.php to users_Registration.php I get the user log_in screen from the file users_LogIn.php.
users_Registration.php code in part line 10 to 18:
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (!WA_Auth_RulePasses("Adminstrator")){
if (!function_exists("GetSQLValueString")) { ................................
Admin index.php code change:
<p><a href="../users_Registration.php">Full Register New Member</a> </p>
<p><a href="../users_Registration_Simple.php">Quick Registration New Member</a> </p>
<p><a href="users_Search.php">Search for user</a></p>
<p><a href="users_Report_Search.php">Filter report</a></p>
</body>
Thanks for the help.
Larry
are you logged in as the administrator?
this code in the registration file is forcing it to only be available if your logged in as the admin:
Larry321390
screen shots
Yes I logged in as adminstrator
Admin
The screen shot is first log in .
After I logged in the 2nd screen shows.
after I click resgister the thrid screen shows up. This is the problem.
I should go straight to the registration page.
What else do I need to send you to find the problem?
Larry
send me the 2 login pages, the admin.index page and the registration page so in a zip archive so i can see the entire code in context rather than the small snippet.
Larry321390
Zipped files are attached.
Larry
the problem is a syntax error on the registration page. in the if statement:
you are missing the second "i" in "Administrator"
it should be:
copy and paste is your friend.
