Map not rendering
Thread begun 9/23/2010 2:37 pm by Ryestenberg156256 | Last modified 9/24/2010 7:22 am by Jason Byrnes | 1276 views | 1 replies |
Ryestenberg156256
Map not rendering
I'm just trying to get a map from a recordset and having problems. I've been able to get it to return the first result, but when I try for multiple I'm not getting anything. Dreamweaver test on the recordset returns all results so I know the connection is working. Google API is accepted and working. Origional results 500+ records then filtered to 42 and still not able to get the Map to render. clientmap.php
using FireFox, the error console reports:
Error: unterminated string literal
Source File: clientmap.php
Line: 2414, Column: 14
Source Code:
street: '13028 Interurban S.
The code producing the error is:
Suite 106',
the error means that this street address has a hard return embedded after before the Suite.
make sure not to have hard returns embedded in your database.
