Modding to get a vertical ribbon
Thread begun 9/22/2010 8:01 am by slonemusic363606 | Last modified 9/22/2010 10:00 am by Jason Byrnes | 2777 views | 3 replies |
slonemusic363606
I'm not a Power Gallery user yet, but I'm thinking of it for a client. The only thing that doesn't seem to fit this customer's requirements is the one about a vertical ribbon instead of an horizontal one.
Is it possible to customize the CSS and the motools script so that it's working vertically or would it require an heavier hack ? I'm more accustomed to jQuery.
Many thanks in advance.
Best regards,
Guillaume Chantraine
it would require completely recreating the gallery div structure and the CSS. It would not be a simple modification to make.
slonemusic363606
Isabella comphi
Thanks for your reply Jason.
Just to make sure I understand the implications correctly :
This would mean the mootools javascript used in Power Gallery is natively capable of handling vertical scrolling if the HTML and CSS are set the right way; or would it also require that I modify this script or even replace it with another one ?
I should be able to handle PHP/HTML/CSS modifications without too much problems. But I've never used the mootools framework. I believe my knowledge of javascript should help but it might be my main weakness if I decide to go this route.
[don't mind the title of the post... just a misplaced captcha entry LOL]
the script will need modifying as well to move vertically, this is not something we will be able to offer support for.
