Bug?
Thread begun 9/22/2010 3:59 am by Cologne | Last modified 9/27/2010 10:57 am by Jason Byrnes | 4143 views | 7 replies |
Cologne
Bug?
Hello, me again with server validation on upload file.
It seems that it only works if you name the uploadfield "image"
if (!function_exists("WADFP_getImageHeight")){
function WADFP_getImageHeight($fileField){
$WA_ImageContentTypes = array("image/gif" => true , "image/jpeg" => true, "image/pjpeg" => true, "image/x-png" => true, "image/png" => true);
$height = -1;
if(isset($fileField) && isset($fileField["tmp_name"]) && isset($fileField["type"]) && isset($WA_ImageContentTypes[$fileField["type"]]) ){
$dimensions = getimagesize($fileField["tmp_name"]);
$height = $dimensions[1];
return $height;
if (!function_exists("WADFP_getImageWidth")){
function WADFP_getImageWidth($fileField){
$width = -1;
$width = $dimensions[0];
return $width;
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (isset($_POST["button"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_up2_474_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_FILES["image"]))?"image":"") . "",true,1);
$WAFV_Errors .= WAValidateFE(((isset($_FILES["image"]))?"image":"") . "",".gif, .jpg, .jpeg, .png",true,2);
$WAFV_Errors .= WAValidateNM(((isset($_FILES["image"]))?$_FILES["image"]["size"]:"") . "",0,500000,"",",.",true,3);
$WAFV_Errors .= WAValidateNM(WADFP_getImageWidth((isset($_FILES["image"]))?$_FILES["image"]:"") . "",50,"","",",.",true,4);
$WAFV_Errors .= WAValidateNM(WADFP_getImageHeight((isset($_FILES["image"]))?$_FILES["image"]:"") . "",50,"","",",.",true,5);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"up2_474");
<head>
<title>Unbenanntes Dokument</title>
</head>
<body>
<form action="" method="post" enctype="multipart/form-data" name="form1" id="form1">
<p>
<label for="image">Foto</label>
<input type="file" name="image" id="image" />
</p>
<p>
<input type="submit" name="button" id="button" value="Senden" />
</p>
</form>
</body>
</html>
$_SESSION['WAVT_up_801_Errors'] = "";
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_FILES["up"]))?"up":"") . "",true,1);
$WAFV_Errors .= WAValidateFE(((isset($_FILES["up"]))?"up":"") . "",".gif, .jpg, .jpeg, .png",true,2);
$WAFV_Errors .= WAValidateNM(((isset($_FILES["up"]))?$_FILES["up"]["size"]:"") . "",0,500000,"",",.",true,3);
PostResult($WAFV_Redirect,$WAFV_Errors,"up_801");
<head>
</head>
<body>
<p>
<label for="up">Foto</label>
<input type="file" name="up" id="up" />
</p>
<p>
</p>
</form>
</body>
</html>
Cheers
Denis
can you be a bit more specific on the problem you are having?
I have tested both code samples, and both will fail validation if the conditions you have added are not met.
Cologne
hi jason, i was more iritated by the look. I was so sure that there was a difference between the two codes, but its no.
Everything is fine and works well.
Sorry for that posting, you can delete if you want :-)
Im sorry,
Denis
"irritated by the look" does not constitute a bug.
there _is_ a difference between the two.
In the first one, you have the following validation:
a file is required
the extension must a gif, jpeg, jpg or png
the size must be less then 500000 bytes
the width must be less then 50
the height must be less than 50
the second one you are not validating the width or the height, but both work. no bug.
Please, when reporting a problem, include specific details on what exactly the problem is. If the "look of the code is irritating" you, include that info, also include what specifically irritates you about it.
Cologne
hello jason,
i got a little blackout when i saw that. The code with image i saved to have it by the hand. When i reproduced it with up, i thought the word image is part of the extension :-) i did that 2-3 times and really thought IMAGE must be in the code? So I asked if this could be a bug.
:-) cheers,
denis
Thank you for the clarification, but it was not clear what you where asking in the initial post.
The initial post was very vague and did not include the details that you where asking about the "$_FILES["up"]" versus "$_FILES["image"]" code.
The $_FILES collection is much like the $_FORM or $_GET collection, but for File fields in a multipart/form-data encoded form.
There is a $_FILE variable for each File field you add to the form, in the same way that each text element in the form will have a $_POST variable.
Cologne
Hi Jason,
now I know what was wrong :-)
I looked again on my saved upload file.
$WAFV_Errors .= WAValidateRQ(((isset($_FILES["image"]))?$_FILES["image"]["name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateFE(((isset($_FILES["image"]))?$_FILES["image"]["name"]:"") . "",".gif, .jpg, .jpeg, .png",true,2);
The RQ and File-extension looks diffrent: (((isset($_FILES["image"]))?$_FILES["image"]["name"]:"") <--- this is my saved file. There is 2 times $_FILE
When I now create a server validation there is only 1 $_FILE.
Was the code changed?
Denis
that code will be created if you select the Field Name binding instead of the Simple File Name binding.
