2 Server validations on page
Thread begun 9/21/2010 9:15 pm by Cologne | Last modified 9/23/2010 1:37 pm by Jason Byrnes | 2848 views | 5 replies |
Cologne
Hello,
I got a big problem. I copy and paste my standard server validation on every page (before page loads).
I saw that it got a special number and the name of the page.
for example WAVT_profileimage_837_Errors
Later I created a server validation for the form on the page.
A new name and a new number was created. but in the "show if" the first name and nuber was used, so the show if doesnt work.
how can I fix that without doining everything new?
Denis
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if ("" == "") {
$WAFV_Redirect = "index.php";
$_SESSION['WAVT_server_345_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateUR($_GET['url'] . "","false",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"server_345");
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos($_SERVER["HTTP_REFERER"], $_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"]) > 0) && isset($_POST)) {
$WAFV_Redirect = "server.php";
$_SESSION['WAVT_server_102_Errors'] = "";
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ($_POST['test'] . "",true,2);
PostResult($WAFV_Redirect,$WAFV_Errors,"server_102");
<head>
<title>Unbenanntes Dokument</title>
</head>
<body>
if (ValidatedField('server_345','server_345')) {
if ((strpos((",".ValidatedField("server_345","server_345").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
dfgsdfg
<?php //WAFV_Conditional server.php server_345(2:)
}?></body>
</html>
edit the initial server validation in the server behaviors panel instead of adding a new one.
Cologne
but i need two diffrent trigger...on before page load and one on press button.
I am logging this as a bug, in the mean time, apply your form validation and validation entries before copying in the validation for before page load.
Cologne
hi, jason, i dont understand that? Will i have both triggers?
i'm just sugesting you reverse you process.
you said you copied your standard validation code to the page, then applied a second server validation.
apply the server validation. Add the validated entries code, after the page is complete, copy in the standard validation.
This way the standard validation os not conflicting while you create the page.
