Framework updated
Thread begun 9/21/2010 8:15 pm by danielsebas | Last modified 9/24/2010 7:49 am by Ray Borduin | 2062 views | 3 replies |
danielsebas
Framework updated
Hi I update framework and started my site all over again and I still have the same errors
Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /Users/Dani/Sites/dsmusic/register/WA_SecurityAssist/Helper_PHP.php:10) in /Users/Dani/Sites/dsmusic/WA_SecurityAssist/Helper_PHP.php on line 48
I am using site sculpture and user registration solution in the register folder
I also still have the redeclare rel2abs error
yes... unfortunately we'll have to fix the problem in securityassist as well it appears.
The issue is that you have two versions of the security assist files in two sections of the site. This isn't something we can fix in framework itself.
Probably the best solution is to change all of the references in your site to point to the same securityassist file. It appears you have the same file in:
and:
maybe do a find in your site for:
and make sure they all point to one location or the other and then the problem should go away.
danielsebas
I was wondering if I can use all the security assist files from the user registration solution instead of the CMS security assist files because they are different, the ones from the solution let you have the two login parts, the profile update for one level and the protected page when you verify your mail.
You could, but you would have to move this code:
case "Super Administrator":
$comparisons[0] = array(TRUE, "".((isset($_SESSION['SuperAdminLogin']))?$_SESSION['SuperAdminLogin']:"") ."", 1, "".((isset($GLOBALS['WAGLOBAL_Admin_Password']))?$GLOBALS['WAGLOBAL_Admin_Password']:"admin") ."");
break;
to the HelperGroupRulesPHP.php file from the powercms to the user registration version. The rest of the files should be identical.
