Can't Edit an Existing Form with CSS Builder
Thread begun 9/21/2010 7:33 pm by Jim376112 | Last modified 9/22/2010 7:29 am by Jason Byrnes | 1856 views | 1 replies |
Jim376112
Hello,
I am trying to "integrate" the nice features of CSS Form Builder with some features that I can only get with some Dreamweaver Spry validations.
My 1st approach was to use CSS Form Builder to edit an existing form. Using CSS Form Builder I added to the existing form a new Line at the bottom with a CAPTCH and a Security Question. When the Wizard generated the form it produced the attached error message stating that it needed to alter a locked section of code and couldn't. The existing form being edited was on a page that was based upon a Dreamweaver Template and also, the form was on a Spry Tabbed panel. I don't know if either of these factors blocked the wizard.
My 2nd approach was to first build a new form in CSS Form Builder in a new (standalone) .php file. This new file was able to replicate some but not all of the Spry validation features I had built in the original form. That form was generated OK but now it's not clear how I can replicate some of the Spry Validation features that I couldn't specify in CSS Form Builder.
For example, in the original/existing form I had used the "Spry Validation Confirm" to confirm that a 2nd entry of an Email address matched the 1st entry of the address. As another example, I had a Spry Textarea that used the Spry option to dynamically display the number of available characters remaining to be typed relative to a max number of characters I had specified.
If I, say, select the Textarea and then try to apply Spry Validation Textarea I get the error "You cannot insert this widget into a validation widget". I get the same error if I select the 2nd Email address field and try to apply "Spry Validation Confirm".
So, my question is, how can I construct a form that combines both the features supplied by CSS Form Builder but that also uses some additional Spry Validation that CSS Form Builder doesn't offer?
Thank you.
The error you are getting is a common one when working with templates in Dreamweaver.
There is no solid fix for the issue, but I have discovered a workaround. See the following thread for details:
showthread.php?t=4509
as far as adding other behaviors to an existing spry element, you will need to edit the spry behavior that is already applied.
if you select a spry element, you should notice a blue bounding box around it, click this bounding box, then go to the property inspector to edit the spry behavior.
