Delete All Files From Folder and Table Then delet folder
Thread begun 9/21/2010 9:11 am by Cologne | Last modified 9/21/2010 9:34 am by Jason Byrnes | 1262 views | 1 replies |
Cologne
can someone please take a look. The code works but I am not so sure if the code is coorect :-)
<?php require_once('Connections/MyDB.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("webassist/file_manipulation/helperphp.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_myDB, $myDB);
$query_allImages = "SELECT galleryid, image FROM gallery";
$allImages = mysql_query($query_allImages, $myDB) or die(mysql_error());
$row_allImages = mysql_fetch_assoc($allImages);
$totalRows_allImages = mysql_num_rows($allImages);
<?php do { ?>
$WA_DeleteFileResult1 = false;
if(!($totalRows_allImages == 0)){
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("test/", "".$row_allImages['image'] ."");
// WA Application Builder Delete
if ($WA_DeleteFileResult1) // Trigger
$WA_connection = $IchBinMusiker;
$WA_table = "gallery";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "galleryid";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldValuesStr = "".$row_allImages['galleryid'] ."";
$WA_comparisonStr = "=";
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_IchBinMusiker;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
<?php } while ($row_allImages = mysql_fetch_assoc($allImages)); ?>
rmdir('test');
Cheers
Denis
as far as I can tell, it looks correct.
