Position
Thread began 6/11/2009 2:46 am by meister281653 | Last modified 6/11/2009 10:53 am by Ray Borduin | 3130 views | 6 replies |
meister281653
Position
Hi there,
I create a Layout with HEADER.
I create a new DIV in the header. how can i fix the POSITION of that DIV? Its only possible to change FLOAT, MARGIN and PADDING.
How can I FIX a position?
If I work with iE and FF it fails in FF. The logo is in FF not 5pixel from the top.
i.php
Denis
Did you find a solution? It looks the same to me in FF and IE... what version of IE were you using?
meister281653
Its FF 3.0.10 and iE7
but right now I got more problems.
index10.php
looks fine in iE7 and destroyed int that F* ff.
why cant sculptor make it all look the same?
meister281653
here is a big gab thats only in the FF!
It looks like the menu ul isn't inside the topNavigation
it goes: header, ul, script, topNav
seems like the ul and script should be inside the topNav
The gap seems to have something to do with the differences in how the browsers handle the <p> tag. If I remove the <p> tag from the first text block the gap disappears as well.
It actually has the gap in IE8, safari, and FF. Previous versions of IE show without the gap, so the better question might be why don't earlier versions of IE have the gap which it seems show in modern browsers.
meister281653
so i put the cssmenuwriter navigation wrong into my sculptor created site????
They somehow are in the wrong order. I can't claim to be sure how they got that way.
