Editing Captcha Colours, Noise etc.
Thread begun 9/21/2010 5:50 am by Dave Buchholz | Last modified 9/22/2010 6:55 am by Jason Byrnes | 4526 views | 13 replies |
Dave BuchholzBeta Tester
I must be having a particularly dim day as I cannot find anywhere to change the setting for the Captcha as I find the default settings unreadable
I don't have version 2 installed but in version 1 to edit captcha settings you would go to the edit design wizard. Select Form Elements the captcha from the drop down menus.
If I am on the right screen the option to edit appears to be grayed out
No, this is not the right screen.
The captcha settings are changed in the edit design interface, not the edit form contetns interface.
On the first screen, select to edit the design. When editing the design select form elemtns, then captcha to edit the captcha settings
ok so to be clear I choose the edit button shown here:
and then the edit button shown here:
if so that takes me to the screen I posted originally
below the chose a form section, you can choose your design.
Click the edit button next to the design you selected.
there is no edit button there:
try the customize css button.
that takes me to this screen
in the first select that currently says form, select Form Elements.
This will prompt a second select list to show. In the second select list select Captcha
