Discount Rule Help
Thread begun 9/21/2010 3:29 am by Dave Buchholz | Last modified 9/22/2010 3:01 pm by Jason Byrnes | 6487 views | 22 replies |
Dave BuchholzBeta Tester
Discount Rule Help
I have a discount rule for buy 6 and get the cheapest free that looks like this:
//eCart Rule
function WAEC_eCart1_Buyany6TTProductsandgettheCheapest1Free()  {
  $totalDiscount = 0;
  if (true && ((sizeof($this->Items) > 0) && (( ((($this->ConditionalTotal("Quantity", "TypeID", "1")) + ($this->ConditionalTotal("Quantity", "TypeID", "2")) + ($this->ConditionalTotal("Quantity", "TypeID", "3")) + ($this->ConditionalTotal("Quantity", "TypeID", "4")) + ($this->ConditionalTotal("Quantity", "TypeID", "5")) + ($this->ConditionalTotal("Quantity", "TypeID", "7")) + ($this->ConditionalTotal("Quantity", "TypeID", "8")) + ($this->ConditionalTotal("Quantity", "TypeID", "9")) + ($this->ConditionalTotal("Quantity", "TypeID", "10")) + ($this->ConditionalTotal("Quantity", "TypeID", "12")) + ($this->ConditionalTotal("Quantity", "TypeID", "16")) + ($this->ConditionalTotal("Quantity", "TypeID", "17")) + ($this->ConditionalTotal("Quantity", "TypeID", "18")) + ($this->ConditionalTotal("Quantity", "TypeID", "19"))) >= 6) )))) {
    $totalDiscount += $_SESSION['tt6get1'];//Result
  return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
where I am checking the quantity of the Product Type ID column in the cart which works great if a single line total of the Product Type ID is greater than or equal to 6 BUT I would like it to work if the sum of the Product Type ID line totals is greater than or equal to 6.
How can I make a rule that can do this please.
CraigRBeta Tester
Hi Dave,
I must be a bit slow today (not interpreting the question)
I copied the rule onto one of my test stores, and reduced the item types to 1, 2 or 3, (to fit in with my own data)
if i have a total of 6 items from any combination of these itemtypes, the rule seems to trigger.
i assume that isn't what you want to do.
That is exactly what I want to do but for some reason it isn't working for me, I wonder if the order of discounts makes a difference ?
CraigRBeta Tester
it shouldn't make any difference, but i just changed my order to 2,1,3 and it still works.
i presume you checked the obvious stuff, like all the ItemTypes have the expected Id's and you have copied the eCart folder to the server ?
one thing I always when I have rule that is not behaving as expected is create a second cart display page on this page, I set the display manager to show all columns from the cart, seeing all the information stored in the cart often helps me find the cause often problem.
Good advice Jason, I will do just that
ok I have uploaded the new test files to my development server, if I add 6 of one item to the cart the discount rule is triggered correctly
if I add two quantities of the same product type (the number after the product type is the ID that I am checking for) then the discount rule doesn't get triggered
If I add two quantities of different product types (both covered by the rule) the discount rule still isn't triggered
I am obviously missing something simple, but what ?
can you send a copy of the cart include file so i can try testing on my end.
Jason,
here you go, thanks
in my test i created two add to cart buttons, one set the TypeID to 1, the other set the TypeID to 2, I can add three of one item and 3 of the other and the discount comes through. It is working in my tests.
did you create the cart page to show all columns that I suggested? can you send a link to that cart page?
