Java Error when insert clear session
Thread begun 9/20/2010 2:20 pm by Cologne | Last modified 9/23/2010 1:52 pm by Jason Byrnes | 2779 views | 5 replies |
Cologne
when I want to insert CLEAR ALL SESSION this error shows up, and then nothing happens :-(
Denis
there is an issue we have discovered with Cookies Toolkit Clear Session Values when Security Assist is installed.
If you have eCart 5, Install it after Cookies toolkit to correct the problem, or disable security assist in the extension manager.
Cologne
Hi Jason,
that doesnt help. I deinstalled Cookie and eCart. then installed Cookie and then eCart, the error stays.
delete the Dreamweaver cache file?
or try disabling Security Assist?
Cologne
hi jason, i deactivate sa and set the session delete. Activate it again and copy paste the code.
Will this be fixed in the next release?
Denis
Yes, it is a logged bug and should be fixed in a future update.
