upgrade from irite to html needed changes
Thread begun 9/20/2010 10:01 am by mustang_sally_85344510 | Last modified 9/20/2010 2:51 pm by Dani Chankhour | 896 views | 1 replies |
I just bought the upgrade html editor,
I currently have irite installed.
I know I have to uninstall irite to install html editor.
My question is, what do I do with all the other sites I have built using irite?
Do I have to go through and change/upgrade all of them to html editor?
If so, are there any issues I should know in advance before doing so?
Thank you in advance.
Dani Chankhour
Correct, you have to uninstall iRite and then install HTMLEditor. As far as Editor you already have in your site, you should not have to do anything unless you are planning to change a setting in the Editor. iRite stores its files in an iRite folder so all the Editors should still work as expected. If you decided to make a change to an Editor, you will then have to Upload the HTMLEditor folder which is created using the HTMLEditor.
