Adding Login Failed Message
Thread begun 9/20/2010 8:07 am by Martin | Last modified 5/02/2011 9:35 am by Martin | 23007 views | 20 replies |
Martin
Greetings,
I was wondering if there was a way with Power CMS to provide the end user with more feedback than appending the URL with "failed=1&" to let users know that they have entered their password incorrectly?
If so, how would you add a conditional message to the page such as
"Your Login Was Unsuccessful - Please Try Again"
or
"forgot your password? Contact your Super Admin to reset"
Something like this?
Thanks for any help!
Martin
you can use the querystring to trigger a message using an if statement:
<?php if(isset($_GET['failed']) && $_GET['failed'] == "1") { ?>
<?php } ?>
Martin
AWESOME! That worked great!
Martin
Great, glad to hear it's working.
PaulBeta Tester
Can you expand please
<?php } ?>
How might this be applied in a login page where an email input, password imput and submit button exist??
Thankyou, Paul.
in the login behavior, set the failed redirect to go back to itself with the failed=1 querystring variable.
for example if my login page is "login.php" I set the failed redirect in the login behavior as:
login.php?failed=1
then use the code form my previous reply to show the message.
PaulBeta Tester
Got it. Sorted!
Thank you.
you're welcome.
Martin
An example
Greetings,
here is some example code of how I used this...
<h2 class="center" style="color: #red; margin-top: 20px;"><span style="font-weight: bold;"><em>Your Login Was Unsuccessful - Please Try Again</em></span><em>!</em><br />
or contact your <a href="mailto:youremail@yourdomain.com?subject=Client%20Name%20Admin%20Forgot%20Password%20Request">Super Admin</a> to recover your password.</h2>
<?php } ?>
I put this just below the form on the login page and made sure the form action was as follows.
action="users_login.php?failed=1<?php echo(isset($_SERVER["QUERY_STRING"])?"&".($_SERVER["QUERY_STRING"]):""); ?>"
I hope this helps!
Martin
Martin, you dont want to include the failed=1 querystring in the forms action.
you only want to include the failed=1 querystring in the failed redirect of the Authenticate User server behavior.
double click the authenticate user server behavior and set the failed redirect to:
