Can't start the form
Thread begun 9/19/2010 9:03 pm by stprix49407889 | Last modified 9/21/2010 9:50 am by Dani Chankhour | 1784 views | 3 replies |
stprix49407889
Hi!
I followed the instructions on Starting from scratch.
I uploaded the file in my server. And I get the statement:
Warning: require_once(WA_ValidationToolkit/WAVT_Scripts_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/spibr/public_html/chickenFifteen.php on line 1
What am I doing wrong?
Strange, in DW, there is a file name WAVT_Scripts_PHP.php when I click on it there is a statement in yellow that says "WAVT_Scripts_PHP.php cannot be found..."
I appreciate some help on that.
Serge
Dani Chankhour
The error you are getting indicates that you have not upload the WA_ValidationToolkit folder or some of the files in that folder are missing. If the files are missing from with in DW, i recommend that you reapply the form so you get the files. And i recommend that you use an FTP client for uploading your files.
stprix49407889
Hi!
I followed your instructions, it worked and I got the form. But I got another error.
After making the form, after I click the fininsh button, after the Run time, an error appeared: "Error generating form: Type Error: this.themeArray has no properties."
Then when I clicked ok, it says "while executing timer in WA_SiteTools_Progress.htm, ...."
Can you tell me why I get this error and how can I fix it?
Serge
Dani Chankhour
This could be related to a Dreamweaver Cache issue, after closing DW, delete your cache file in the Configuration folder. And if you are still getting that error, try removing the form entirely and reapplying it to the page.
