Field 'ID' doesn't have a default value
Thread begun 9/19/2010 10:51 am by kbettenc296716 | Last modified 9/20/2010 10:44 am by Jason Byrnes | 4511 views | 3 replies |
kbettenc296716
I have, twice now, created new DataAssist sets of php files for a table in my client's database. Both times I get the above error when I try to insert a record using WASartists_Insert.php. Both times on my localhost on my machine. I have never had this happen to me before. The only additional WebAssist function added to the page was HTML Editor on 2 text fields. I have attached Insert php file. Let me know what else you want.
When creating the table, your Index column should be configured as a primary key Column and you should it to be an Auto Number column. This way the database will automatically assign a unique value to that column when a record is inserted.
kbettenc296716
Thanks, I didn't know that was what that message meant. I converted an Access DB to MySQL and the auto-increment was turned off. First and only time that has ever happened.
You're welcome.
