Form is not sending email and not redirecting to thankyou page
Thread begun 9/18/2010 9:11 pm by denniesmit406616 | Last modified 10/21/2010 2:12 pm by Jason Byrnes | 13716 views | 52 replies |
denniesmit406616
Hi.
I am sorry if this question appears somewhere else in the forums, I searched but could not find an answer.
I followed the instructions to set up my contact form: I started with the contactus file given by this site. I added checkboxes, a little css and deleted the captcha. I changed the email address in the WA_Globals.php and uploaded everything.
The validation works fine, but when submitted it does not redirect to the thankyou page. And I am not receiving the email.
you can view my page at: contactus.php
I appreciate the help!
Danielle
neilo
Hi Danielle,
Please could you zip your contactus.php & WA_Globals.php files and post them here?
denniesmit406616
Hi.
I have been playing around with this, but nothing seems to work.
I tried just copy and paste the contacts.php supplied into a page of my own, but that does not redirect to thankyou and does not send email.
this page is located at:
heliskiHelitour_rates2.php
This is the new URL of the page I am trying to make work:
heliskiHelitour_rates.php
Of note: this page used to work, but now has the same bug:
contact.php
On both pages If I input something in all fields, it redirects me to the thankyou page. If I only input an email it just reloads the page. In neither instance does it send an email.
I have input the correct email address in the Globals file. And I did not change anything on my server or email provider, or any of the WA docs.
my zip files are attached
Thanks for any help
denniesmit406616
Ok, I changed the email address in the WA globals file.
Now, I am getting the email! So obviously the problem was that I wasn't using an email address provided by the web host to test this.
BUT
still a problem:
I do not get any validation now. I only get redirected to thankyou and email if I fill in all fields.
If I press submit without filling out all fields it just reloads the page.
some problem somewhere with the validation?
I attached new WA globals file
Thanks!
denniesmit406616
sorry here is the attachment
neilo
Hi Danielle,
I can't see much wrong with it.
The only other thing I can see is that (in heliskiHelitour_rates.php) you may have to correct line 297 & 305, from:
<input type="text" class="inputValue" name="telephone" id="telephone" onblur="if (document.getElementById('nameServerError')) document.getElementById('nameServerError').style.display='none'" value="<?php echo(ValidatedField("contact","telephone")) ?>" />
<span class="textfieldRequiredMsg">A value is required.</span></span>
if (ValidatedField("contact","contact")) {
if ((strpos((",".ValidatedField("contact","contact").","), "," . "8" . ",") !== false || "1" == "")) {
if (!(false)) {
<span id="nameServerError" class="textfieldServerError">Please provide your telephone number.</span>
<?php //WAFV_Conditional contact.php contact(1:)
<input type="text" class="inputValue" name="telephone" id="telephone" onblur="if (document.getElementById(telephoneServerError')) document.getElementById('telephoneServerError').style.display='none'" value="<?php echo(ValidatedField("contact","telephone")) ?>" />
if ((strpos((",".ValidatedField("contact","contact").","), "," . "8" . ",") !== false || "8" == "")) {
if (!(false)) {
<span id="telephoneServerError" class="textfieldServerError">Please provide your telephone number.</span>
<?php //WAFV_Conditional contact.php contact(8:)
Those elements' IDs (two in line 297, one in line 304) need to be unique to validate correctly. Also replace the '1' for '8' in line 301. Can you give this a go and see what happens?
denniesmit406616
Thank you for your reply.
Unfortunately it did not work. It does give me telephone validation now, it did not before.
So what happens is that it asks for telephone and email validation. But if I only fill out these two fields it does not redirect and send message.
It only does that when I fill out all fields.
Something is up with the validation?
I attached the updated version of docs.
Please help
Thanks so much!
neilo
Hi Danielle,
I am not currently seeing any working validation (name email telephone comment) on the linked to heliskiHelitour_rates.php page. Have you changed it? Can you revert to the status described in your last post? Ta.
this code block at the top of the page:
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
$WAFV_Redirect "";
$_SESSION['WAVT_contact_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["telephone"]))?$_POST["telephone"]:"") . "",true,8);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
is there to ensure that the Contact_Name, Email_address, Comments and telephone elements are filled in. The form will only send if those elements have values.
neilo
Hi Danielle,
Try the attached
