CSSFormBuilder Country tables are not compatible with Ecart Country checkout tables.
Thread begun 9/17/2010 3:54 pm by georgevargasa302189 | Last modified 9/21/2010 8:19 am by Jason Byrnes | 1291 views | 1 replies |
georgevargasa302189
I used SecurityAssist to create the login and customer registration pages. Then I used
CSSFormBuilder to implement better looking forms with validation.
All this seemed to work except I noticed when I tried to apply the customer data to the Ecart checkout page the country did not work. The country menu was not updated.
The problem is that the country tables created by CSSFormBuilder are stored as "country,country' instead of 'country code,country', which is what Ecart expects.
I manually corrected this with an editor and carefully copied the tables in the checkout form code and inserted them into the Update and Registration pages. This is kind of tricky because the validation can get easily screwed up.
Is there an easier solution, because this was time consuming and error prone? Or is there a release coming from CSSFormBuilder to correct this?
thank you for bringing this to our attention, I have logged this as a bug in our bug base so it can be corrected in a future version of Form Builder.
