incorrect php.ini settings causing date function errors
Thread begun 9/17/2010 1:42 pm by SaladoGuy | Last modified 9/17/2010 2:12 pm by Jason Byrnes | 3147 views | 3 replies |
SaladoGuyBeta Tester
I'm still learning so many thing I've done wrong may be user error, but I have noticed a few things that crop up repeatedly, that I think WA might consider fixing in future versions of eCart.
Quite often, after setting up a new cart (with all the necessary wizards) on final checkout steps (clicking the last button) I get errors like this:
Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Chicago' for 'CDT/-5.0/DST' instead in /Users/me/Sites/mysite/webassist/email/mail_php.php on line 198
Often seen in conjunction with lines like this:
Warning: Cannot modify header information - headers already sent by (output started at /Users/me/Sites/mysite/Connections/local.php:9) in /Users/me/Sites/mysite/confirm.php on line 344
It always complains about line 198 in mail_php.php, and usually another line in confirm.php (I think it's line 244).
I've been able to remove the error by replacing date() functions with date_default_timezone_set()
For example:
$mailHeader .= "Date: ". date_default_timezone_set('r (T)').$lineEnd;
Often many of the "Cannot modify header information" errors disappear after the date fix.
I'm using Max OS X Snow Leopard, with various combination of "MAMP" and OS X's built in apache for a web server (and mysql of course)
This is not a bug in the software, it is caused by a setting in your PHP.ini file.
in the php.ini file for php 5.3 there is a setting for :
date.timezone
if this is not set properly, you will get the error you are reporting.
The first error is causing the headers already sent error.
see the following php.net page for details:
datetime.configuration.php
Sure, that makes sense. I thought perhaps date_default_timezone_set() might be a beneficial improvement anyway.
The date() function will yield the same result if you have the php.ini file set correctly.
