Weight Units
Thread begun 9/17/2010 7:38 am by cmariedesigns405969 | Last modified 9/17/2010 10:26 am by Jason Byrnes | 2353 views | 3 replies |
cmariedesigns405969
Weight Units
This is my first eCart setup and I am having a problem with Weight Units. I know it is caused by a variable not being set, but I don't know where to fix the problem. The error message I get is:
Undefined variable: itemWeightUnits in C:\inetpub\wwwroot\mysite\htdocs\WA_eCart\eCart1_PHP.php on line 35
I am using eCart5 and have a database set up that contains the weight measurement units for each of my products. I just can't find where to bind this in.
Thanks for your help!
Did this start happening after adding a WeightUnits column to the Cart Object?
After adding a column to the eCart object, you need to update any of your add to cart buttons and bind the new column to the recordset column.
what is the code at line 35 of the WA_eCart\eCart1_PHP.php file?
cmariedesigns405969
This happened after I added my FedEx info, so yes, it was added to the Cart Object at that time, I suppose.
I knew I was just lost in a loop and couldn't remember where to edit the info. Thanks for reminding me it was in the Add To Cart button! Problem now solved.
ok, glad to hear it is working.
