From Registration through Login...
Thread begun 9/16/2010 2:01 pm by fdotmedia | Last modified 9/29/2010 3:30 pm by Jason Byrnes | 8494 views | 15 replies |
fdotmedia
Is there an easy way to login a user when they submit the register button on a register page?
Do I need to make and carry the session variables for username and password?
Ideas?
Add the security assist authenticate user behavior to the to the registration page.
you will need to make sure the insert record behavior does not redirect and that the authenticate user code is after the insert record code, also check the authenticate user behavior on the login page, go to the third step of the wizard, and make sure that any sessions set on the login page are also set on the registration page.
fdotmedia
ok Jason... first off thank for the reply...
Am I supposed to have an action on the form? Self maybe... The form doesn't post nor login...
Here's what I have so far...
<?php require_once('Connections/ReThinkNow.php');?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_ReThinkNow, $ReThinkNow);
$query_classes = "SELECT * FROM rtnClass";
$classes = mysql_query($query_classes, $ReThinkNow) or die(mysql_error());
$row_classes = mysql_fetch_assoc($classes);
$totalRows_classes = mysql_num_rows($classes);
if(isset($_POST["submit"])){
$WA_Auth_Parameter = array(
"connection" => $ReThinkNow,
"database" => $database_ReThinkNow,
"tableName" => "rtnUser",
"columns" => explode($WA_Auth_Separator,"rtnEmail".$WA_Auth_Separator."rtnPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["password"]))?$_POST["password"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"rtnUID".$WA_Auth_Separator."rtnEmail".$WA_Auth_Separator."rtnPassword".$WA_Auth_Separator."rtnUserLevel"),
"sessionNames" => explode($WA_Auth_Separator,"rtnUID".$WA_Auth_Separator."rtnEmail".$WA_Auth_Separator."rtnPassword".$WA_Auth_Separator."rtnUserLevel"),
"successRedirect" => "login.php",
"failRedirect" => "",
"gotoPreviousURL" => FALSE,
"keepQueryString" => FALSE
WA_AuthenticateUser($WA_Auth_Parameter);
and the form...
<form style="width:690px;" action="" method="post" enctype="multipart/form-data">
<p style="padding:0 0 8px 0;"><strong>Bold</strong> fields are required.</p>
<fieldset><legend><img align="top" src="assets/images/step1on.png" border="0" width="28" /> User Information</legend>
<div class="notes">
<h4>User Details</h4>
<p class="last">
Please enter your name and address as they are listed for your debit card, credit card, or bank account.
</p>
</div>
<div class="required">
<label for="first_name">First Name:</label>
<span id="req-fname">
<input name="first_name" id="rtnFName" class="inputText" size="10" maxlength="100" value="" type="text" />
<span class="textfieldRequiredMsg">A value is required.</span>
</span>
</div>
<div class="optional">
<label for="middle_initial">Middle Initial:</label>
<input name="middle_initial" id="rtnMI" class="inputText" size="10" maxlength="100" value="" type="text">
</div>
<label for="last_name">Last Name:</label>
<input name="last_name" id="rtnLName" class="inputText" size="10" maxlength="100" value="" type="text">
</div>
<label for="phone">Phone Number:</label>
<input name="phone" id="rtnPhone" class="inputText" size="10" maxlength="50" value="" type="text">
</div>
<label for="postal">Zip Code:</label>
<input name="zipcode" id="zipcode" class="inputText" size="10" maxlength="50" value="" type="text">
</div>
</fieldset>
<br /><br />
<fieldset><legend>Login Information</legend>
<div class="notes">
<h4>Login Details</h4>
<p>
Your username and password must both be at least 8 characters long and are case-sensitive. Please do not enter accented characters.
</p>
</div>
<label for="username">Email Address:</label>
<input name="username" id="rtnEmail" class="inputText" size="10" maxlength="100" value="" type="text">
<small>May only contain letters, numbers, and underscore (_) and 8-20 characters long.</small>
</div>
<label for="password">Password:</label>
<input name="password" id="rtnPasswrod" class="inputPassword" size="10" maxlength="25" value="" type="password">
<small>Must be 8-25 characters long.</small>
</div>
<label for="confirm_password">Please re-enter your Password:</label>
<span id="confirm-password">
<input name="confirm_password" id="confirm_password" class="inputPassword" size="10" maxlength="25" value="" type="password" />
<span class="confirmRequiredMsg">A password is required.</span>
<span class="confirmInvalidMsg">Your passwords don't match.</span>
</span>
</div>
</fieldset>
<br /><br />
<fieldset><legend>Class Information</legend>
<div class="notes">
<h4>Class Details</h4>
<p>
The classes offered are for individuals to enroll in and
</p>
</div>
<label for="username">Classes Available:</label>
<select name="rtnClass">
do {
<option value="<?php echo $row_classes['rtnCTitle']?>" ><?php echo $row_classes['rtnCTitle']?> | <?php echo $row_classes['rtnCPrice']; ?></option>
} while ($row_classes = mysql_fetch_assoc($classes));
</select>
<small>Choose your class from the list of available classes above.</small>
</div>
</fieldset>
<br /><br />
<fieldset>
<div class="submit">
<div>
<input class="inputSubmit" value="Next Step ยป" name="submit" type="submit">
</div>
</div>
</fieldset>
</form>
it looks like the authenticate user code is before the insert record code.
you will need to make sure the insert record behavior does not redirect and that the authenticate user code is after the insert record code.
the user cannot be logged in until the user has been stored in the database. PHP code is executed top to bottom.
right now, the authenticate user behavior is checking the database for a user that has not been inserted to the database yet.
fdotmedia
Thanks for your help Jason... I have one additional question regarding passing variables through the login...
I have a user that registers, let's say he's uid=100, how do I pass that variable from registration.php through login.php to step-two.php??? I've tried filtering the recordset by URL parameter, Session variable, form variable and I can't get it to pass through any of the recordset update able details...
no matter what variables I filter with - I always get record #1...
any ideas?
if you set the authenticate user behavior up properly, it will store the UID in a session variable when the login occurs.
fdotmedia
Thanks for the reply Jason...
I believe I have login session setup correctly, apparently I don't since it doesn't actually set the session correctly
On the reg.php page I have the authenticate user setup AFTER the insert record using the following data...
"sessionColumns" => explode($WA_Auth_Separator,"rtnUID".$WA_Auth_Separator."rtnFrNumber".$WA_Auth_Separator."rtnEmail".$WA_Auth_Separator."rtnPassword".$WA_Auth_Separator."rtnLName".$WA_Auth_Separator."rtnFName".$WA_Auth_Separator."rtnUserLevel"),
"sessionNames" => explode($WA_Auth_Separator,"rtnUID".$WA_Auth_Separator."rtnFrNumber".$WA_Auth_Separator."rtnEmail".$WA_Auth_Separator."rtnPassword".$WA_Auth_Separator."rtnLName".$WA_Auth_Separator."rtnFName".$WA_Auth_Separator."rtnUserLevel"),
I want to set the users rtnUID, rtnFrNumber, rtnEmail, rtnPassword, rtnLName, rtnFName and rtnUserLevel
On the login.php page I have, literally, exactly the same 'sessionColumns' redirecting the user to a profile.php page that "should" show the current new user, except I only get the 1st row in the DB...
Keep in mind I am a dumbass and if it wasn't for the drag and drop tools WA makes, I'd be totally lost...
BTW, the tool should work with CS5 - right?
Any help would be greatly appreciated...
Ted
send a copy of your login and registration pages in a zip archive please.
yes, if you have the most recent extension versions, they are CS5 compatible.
fdotmedia
The following zip includes;
registration1.php
step-two-login.php
step-two.php
Thanks Jason...
am I missing something? your registration page does not have any form elements on it that correspond with the insert record behavior or the login behavior?
