Search works in Mozilla + Safari,not in IEx! Help!!
Thread begun 9/16/2010 2:31 am by Banksie | Last modified 9/16/2010 11:03 am by Jason Byrnes | 3715 views | 5 replies |
Banksie
I'm currently using DA2.0.7 and have used the wizard to create search / results pages. However, the search and results works perfectly in Mozilla (Firefox) and Safari yet fail miserably in IE.
The search form (on every page) contains 1 field searchText that is compared to content in 3 database fields to produce results on the search_Results.php page. Using a test string of u217, IE presents ALL fields in the database, Firefox & Safari serve up the required 1 product.
Obviously an IE issue with DA code and sessions? Any advice / assistance gratefully received.
The site concerned is live and can be found at www.arrowexport.co.uk
Look forward to your comments.
Gary
this is a limitation of IE with small forms.
When you have a small form, IE will not pass the button value along.
One work around is to add a few hidden fields:
<input type="hidden" name="hidden" value="1" />
another work around is to use the any form post trigger in DataAssist search instead of the button.
Banksie
Thanks for that - I can't trigger on "any form post" as I use at least one other (eCart) form on each page.
I've added 8 hidden fields to the search form, but still no joy! Anything else I could try?
trigger on the text box. next to the trigger, click the lightning bolt and select the search text field from the dynamic data bindings.
Banksie
Done - all seems to work now. Thanks for your help.
Great, glad to hear it is working.
