changing field labels
Thread begun 9/15/2010 3:06 pm by chris373619 | Last modified 9/16/2010 2:17 pm by Jason Byrnes | 3981 views | 9 replies |
chris373619
I'm sing the latest version of Universal Email. How do I change the form field names on my form? I need to get rid of the "Contact_Is_Group" portion of field names. I have everything working I just need to change the names. How would I do that without messing everything up? Also how do I get rid of the "contact submit: Submit" field on the return email?
Thanks,
Chris
in the email template file, the code to write the lable in the email will look like:
<?php echo(str_replace("_"," ",$pkey)); ?>
change it to:
<?php echo(str_replace("_"," ",str_replace("Contact_Is_Group_"""$pkey))); ?>
to remove that p0rtion of the field name in the email.
near the top of the email template file, you will see the following two lines:
$removeIncludes = array();
$removeIncludes[] = "Security";
change that to:
$removeIncludes[] = "submit";
this will remove the submit button from the email ass well.
chris373619
I'm having trouble with the first part of you instructions.
<?php echo(str_replace("_"," ",str_replace("Contact_Is_Group_", "", $pkey))); ?>
I added it in and it didn't work. Then I looked at it and thought maybe it had 2 extra spaces.
<?php echo(str_replace("_"," ",str_replace("Contact_Is_Group_","",$pkey))); ?>
But that didn't work. Any Ideas? I'm using the "block.php template"
The other code worked perfect!
send a copy of the block.php page and the form page in a zip archive please.
chris373619
The file is attached.
please send the form page also.
chris373619
This is my php file.
in the form, the labels are using "Contact_Us_group" instead of "Contact_Is_Group"
change:
<?php echo(str_replace("_"," ",str_replace("Contact_Us_group_"""$pkey))); ?>
chris373619
That was it. Just a typo. That works perfect now. Thanks so much for your help! That was fast!
no worries, glad to hear it's working.
