Z-index problems in IE
Thread begun 9/15/2010 11:26 am by templemedia365477 | Last modified 9/15/2010 1:21 pm by Jason Byrnes | 2205 views | 4 replies |
templemedia365477
Hi, I've got a vertical menu with a bunch of Level 1 menus slipping behind my Flash in the main content area of the page. I tried giving the Flash object a Z of 80 and that took care of the problem in Firefox. IE, no way, no how.
Tried giving the level 1 tag a z of 110, then the left column div itself a z of 110 - nada.
Help! Thanks!!! ttt
www.seminolefeed.accountsupport.com
you need to set the wmode property of the flash object to transparent.
templemedia365477
wmode
Hi - thanks for the response. I'm in Dreamweaver. I'm not a newbie, but this is advanced for me - here is the code on the flash:
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="650" height="360" title="Seminole Wellness">
<param name="movie" value="panel.swf" />
<param name="quality" value="high" />
<embed src="panel.swf" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="650" height="360"></embed>
</object>
Can you give me the code for wmode and where it goes? Should I set it in the doc itself or in all the menu.css's?
Again, thanks for the response...ttt
templemedia365477
Fixed!
Thanks, thanks! Under parameters. Thanks again, brilliance...
glad to hear it is fixed.
