mind the gap!
Thread begun 9/15/2010 4:59 am by CraigR | Last modified 9/15/2010 12:13 pm by CraigR | 1761 views | 3 replies |
CraigRBeta Tester
mind the gap!
i just had my first go making a template using CSS sculptor, and then importing it into site sculptor.
the template is one with a fixed footer, which appears ok until i start editing the site content.
if i delete content via CMS, I get a gap appearing between the content and the footer, can't work out why
index.php is the home page.
Most other pages appear OK, but I deliberately edited the content on the 'about' page to show the problem
aboutus.php
I think you can fix the problem by setting the background image on the outerwrapper to match the rest of the page:
screen.css line 123
#outerWrapper {
background-image:url("../images/line.jpg");
background-repeat:repeat-y;
CraigRBeta Tester
thanks Ray.
I remember having an issue like this a while ago, and I fixed it by setting negative margins for the footer and an equivalent bottom padding on the content wrapper, but your suggestion is a lot neater. - and it works!
CraigRBeta Tester
Hmm, still causing me problems.
when viewing in a window, as the window is reduced in height, the salads, desserts & price list content div shrinks
but when viewing contact us and testimonies, it doesn't seem to.
i think the div is shrinking by a certain amount in each case, but the additional content is masking it to an extent
**Update, i tried adding a negative top margin to the footer and bottom padding to the content wrapper div, its not quite right, but nearly there. This seems to be the fix **
