Security Assist Errors on PowerCMS Pages
Thread begun 9/14/2010 1:04 pm by johnlanglois | Last modified 9/17/2010 6:38 am by Jason Byrnes | 1862 views | 3 replies |
johnlanglois
There are several pages, such as admin/index.php or manage_users.php, where I see Dreamweaver8 flagging errors when I open the page.
The errors range from the record set having no connection to generating a Javascript error such as "While executing onLoad in WADA Repeat Selection.htm a Javascript error occured."
Why are these obvious errors in the code?
Is it the nature of the PowerCMS product that WA users who already own Security Asssist and many of your other products were not meant to make changes to the PowerCMS pages?
My goal in this is to avoid forcing the user to log in a second time, when they have already logged in elsewhere in the system.
Rather than remove the authentication code in index.php, what variables should I set so that the system processes an Admin or Super Admin user?
Thanks.
the problem is caused by the solution packs being in a sub folder of your Dreamweaver site.
To edit the solution pack files using the Dreamweaver Extensions, the solution pack files must be at the root of the Dreamweaver site.
Dont confuse this as meaning the root of the Website. I am only referring to the site as it is defined in Dreamweaver.
the way that I manage this is to create a sub folder on my testing server for the main site, and a separate sub folder for each solution pack. I use mamp for my teting server, so the root of my site:
localhost
maps to:
/Applications/MAMP/htdocs/
under the htdocs folder, I create a create a folder for the main site:
/Applications/MAMP/htdocs/mySite
in the site definition, for the Testing server i use the address:
mySite
for the Remote Site settings, I set the ftp information and set the upload folder to the /htdocs which is my remote website root.
I then create a seperate folder for power store:
/Applications/MAMP/htdocs/PowerStore
I create a separate Dreamweaver site and point it to the power store folder.
for the testing server URL, i use:
PowerStore
for the Remote Site settings, I set the ftp information and set the upload folder to the /htdocs/PowerStore
this puts the power store files into the main site under the PowerStore
Basicly, the concept is to separate the main site and the solution packs into differant Dreamweaver sites locally, then put them back together into one Website when uploaded to the server.
I just did a quick test, and can confirm that as long as you use the same admin username and password for each of the solution packs, the login for one will keep you logged in when going to the others admin page.
johnlanglois
Why doesn't the WA_Globals files fix this
I thought the whole point of having the WA_Globals file was that it would free up the code from being hard wired into a particular location.
Thanks for the Dreamweaver tips. It seems, though, that I will not be able to edit pages built with the PowerCMS code directly, which is sort of the whole point of using Dreamweaver.
I want to test the code before I put it out on the live site.
The Gl0bals file effects how the site runs on the server, it has no bearing on the site in Dreamweaver.
You can use Dreamweaver to edit the solution recipe files as long as the solution recipe files are at the root of the Dreamweaver Site.
