WADA Search error - checkbox??
Thread begun 9/14/2010 3:09 am by steve287725 | Last modified 9/14/2010 7:26 am by Jason Byrnes | 2652 views | 4 replies |
steve287725
Hello there - hope you can help.
I am using DataAssist 2.06 and I am getting an error when I use a checkbox field using DataAssist Search - the field is set up OK on the search page and it has a static checked value of 1.
The database is MySQL and the field is a TINYINT with a length of 1 - values 1 for true, 0 for false,
All the fields have values in them.
If the checkbox is NOT checked all is OK and all the records return on the results page.
If the checkbox IS checked then I always get the following;
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'show = 1) ORDER BY full_item_details.category_description ASC LIMIT 0, 10' at line 1
I attached the checkbox setup.
It does not seem to make any difference as to whether I inset a value in the second field 'setup' box or not.
The code in the page header is;
//comparison list additions
$WADbSearch1->addComparisonFromEdit("UID","S_UID","AND","=",1);
$WADbSearch1->addComparisonFromEdit("toyname","S_toyname","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("category","S_category","AND","=",1);
$WADbSearch1->addComparisonFromEdit("agerange","S_agerange","AND","=",1);
$WADbSearch1->addComparisonFromCheck("show","S_show","1","","AND","=","=",1);
Can you please shed any light on this?
Many thanks
Steve
Dave BuchholzBeta Tester
Steve,
the following line of code
Originally Said By: steve287725
should read
$WADbSearch1->addComparisonFromEdit("show","S_show","AND","=",1);
for the search to work with a checkbox
steve287725
Hello - thanks for that but I have already tried this, however here is the new code;
Still get this when the box is checked with a value of 1;
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'show = 1) ORDER BY full_item_details.category_description ASC LIMIT 0, 10' at line 1"
If it helps here is the string from the address bar;
http://localhost/<sitename>/admin/full_item_details_Results.php?S_UID=&S_toyname=&S_show=1&S_category=&S_agerange=&WADbSearch1=Submit&Search.x=43&Search.y=10[/url]
This seems OK to me?
Steve
Steve,
all I can say is that the code I gave you works for me every time, there must be an error somewhere but without going through the whole thing with you, which I don't have time to do at the moment, I can't help you any more.
Perhaps one of the WA techies can shed some light on this for you.
Sorry I can't be of more help.
please send a copy of your page in a zip archive so I can examine the entire page code.
