iE8 no error message
Thread begun 9/13/2010 10:44 am by Cologne | Last modified 10/01/2010 7:26 am by Jason Byrnes | 3273 views | 6 replies |
Cologne
on the iE8 there are no ERROR MESSAGES shown :-(
register.php
Denis
I notice you are using frames. I suspect this has a lot to do with the problem. in your test file, you dont seam to be really using frames at all, is there a reason this form is in a frame?
What is the trigger you are using for validation? try using the button press trigger.
Cologne
Jason :-)
I think the problem is, that I use a redirection of my provider and he puts lots of code onto my page. So it wont be shown in the iE. in FF and Chrome it works.
Maybe I need to create an DNS for the redirection.
Thanks so far
Denis!
Rune Brynestad
I have the same problem too. The Server validation error messages in IE8 will not show when the form runs inside a frame. However, if you turn your Cookies and Session Cookies in IE8 on it works in IE8 too.
Since Cookies and Session Cookies are turned off in IE by default a lot of users get a bad user experience when the form runs inside a frame.
Does anybody have a workaround ?
I have a newly created form that runs inside a frame on live URL here:
Etablerartilskot+for+Studentbedrifter/
I'm also attaching my source file so you can have a look at it.
The validation error messages for the text and textarea fields works because of the client side/spry validation, but the error messages for the file fields will not show because they are server validation only.
Regards
Rune
i did a quick google search for "cookies and iframes" and found this code snippet:
<?php header('P3P:CP="IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT"'); ?>
from this page:
IE-Blocking-iFrame-Cookies
try adding that code at line 1 of your page.
Rune Brynestad
This code snippet works perfect !!
Thanks again for helping me.
Regards
Rune
awesome, glad to hear it worked.
