File field path is lost
Thread begun 9/12/2010 9:42 am by nickj | Last modified 9/13/2010 7:24 am by Jason Byrnes | 1524 views | 2 replies |
nickj
In this insert file,when I select a file to to be used as a link on the page, the path is lost. I get the file name loaded but the "../" is lost.
Nick
<?php require_once("../../Connections/conn_ArtCards.php"); ?>
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once('../../Connections/conn_ArtCards.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_conn_ArtCards, $conn_ArtCards);
$query_rsMenu_pos = "SELECT Id_lbl, value_lbl, label_lbl FROM label WHERE group_lbl = 11";
$rsMenu_pos = mysql_query($query_rsMenu_pos, $conn_ArtCards) or die(mysql_error());
$row_rsMenu_pos = mysql_fetch_assoc($rsMenu_pos);
$totalRows_rsMenu_pos = mysql_num_rows($rsMenu_pos);
$query_rsParent = "SELECT * FROM menuDY WHERE parent_menu_mnu = '0'";
$rsParent = mysql_query($query_rsParent, $conn_ArtCards) or die(mysql_error());
$row_rsParent = mysql_fetch_assoc($rsParent);
$totalRows_rsParent = mysql_num_rows($rsParent);?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $conn_ArtCards;
$WA_table = "menuDY";
$WA_sessionName = "WADA_Insert_menuDY";
$WA_redirectURL = "menuDY_Results.php";
$WA_keepQueryString = false;
$WA_indexField = "id_mnu";
$WA_fieldNamesStr = "name_mnu|front_mnu|link_mnu|close_class_mnu|text_mnu|back_mnu|parent_order_mnu|parent_menu_mnu|sub_order";
$WA_fieldValuesStr = "".((isset($_POST["name_mnu"]))?$_POST["name_mnu"]:"") ."" . "|" . "".((isset($_POST["front_mnu"]))?$_POST["front_mnu"]:"") ."" . "|" . "".((isset($_POST["link_mnu"]))?$_POST["link_mnu"]:"") ."" . "|" . "".((isset($_POST["close_class_mnu"]))?$_POST["close_class_mnu"]:"") ."" . "|" . "".((isset($_POST["text_mnu"]))?$_POST["text_mnu"]:"") ."" . "|" . "".((isset($_POST["back_mnu"]))?$_POST["back_mnu"]:"") ."" . "|" . "".((isset($_POST["parent_order_mnu"]))?$_POST["parent_order_mnu"]:"") ."" . "|" . "".((isset($_POST["parent_menu_mnu"]))?$_POST["parent_menu_mnu"]:"") ."" . "|" . "".((isset($_POST["sub_order"]))?$_POST["sub_order"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_conn_ArtCards;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Insert menuDY</title>
<link href="../../WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="../../WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="menuDY_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="../../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">ID</th>
<td class="WADADataTableCell"></td>
</tr>
<tr>
<th class="WADADataTableHeader">Menu</th>
<td class="WADADataTableCell"><select name="name_mnu" id="name_mnu">
<option value="">Select One</option>
do {
<option value="<?php echo $row_rsMenu_pos['value_lbl']?>"><?php echo $row_rsMenu_pos['label_lbl']?></option>
} while ($row_rsMenu_pos = mysql_fetch_assoc($rsMenu_pos));
$rows = mysql_num_rows($rsMenu_pos);
if($rows > 0) {
mysql_data_seek($rsMenu_pos, 0);
</select>
<input name="front_mnu" type="hidden" value="&lt;li&gt;&lt;a href=&quot;" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Item Type</th>
<td class="WADADataTableCell">&nbsp;</td>
</tr>
<tr>
<th class="WADADataTableHeader">Link<br />
file, document or image</th>
<td class="WADADataTableCell"><input name="link_mnu" type="file" size="50" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">close_class_mnu:</th>
<td class="WADADataTableCell"><input name="close_class_mnu" type="hidden" id="close_class_mnu" value="&quot;&gt;" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">&nbsp;Text/Label</th>
<td class="WADADataTableCell"><input type="text" name="text_mnu" id="text_mnu" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Close</th>
<td class="WADADataTableCell"><input type="radio" name="back_mnu" id="back_mnu" value="&lt;/a&gt;&lt;/li&gt;" />
Single Item no sub-menu<br />
<input type="radio" name="back_mnu" id="back_mnu" value="&lt;/a&gt;&lt;div&gt;&lt;ul&gt;" />
Link to su-menu<br />
<input type="radio" name="back_mnu" id="back_mnu2" value="&lt;/a&gt;&lt;/li&gt;&lt;/ul&gt;&lt;/div&gt;" />
last&nbsp; of a sub-menu&nbsp; up to uper level</td>
</tr>
<tr>
<th class="WADADataTableHeader">Parent Order</th>
<td class="WADADataTableCell"><input type="text" name="parent_order_mnu" id="parent_order_mnu" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Parent Menu</th>
<td class="WADADataTableCell"><select name="parent_menu_mnu" id="parent_menu_mnu">
<option value="0">Top Level</option>
do {
<option value="<?php echo $row_rsParent['id_mnu']?>"><?php echo $row_rsParent['text_mnu']?></option>
} while ($row_rsParent = mysql_fetch_assoc($rsParent));
$rows = mysql_num_rows($rsParent);
if($rows > 0) {
mysql_data_seek($rsParent, 0);
</select></td>
</tr>
<tr>
<th class="WADADataTableHeader">Order:</th>
<td class="WADADataTableCell"><input type="text" name="sub_order" id="sub_order" value="" size="2" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="../../WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="menuDY_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../../WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
mysql_free_result($rsMenu_pos);
mysql_free_result($rsParent);
nickj
The POST is stripping off the path and should only strip off the path to the root!
I think you are misunderstanding how a file field works.
A file field allows the user to select a file that exists on the client computer, not the server.
you cannot simply add a file field and have the file be uploaded to the server, you will need to add additional code to the page for the upload to occur.
The Universal Email extension includes an Upload file server behavior that can be used to transfer the file from the client computer to the server.
as for storing the file name in the database, yes, it will only store the name not the path.
the path will change from page to page depending where it is on the site. when creating the link, you should include the path to the file upload location.
