Multiple selects
Thread begun 9/09/2010 9:45 am by tn228553 | Last modified 9/09/2010 12:15 pm by Jason Byrnes | 1263 views | 1 replies |
tn228553
Multiple selects
I have a multiple select field of zip codes on my registration page like this:
<select name="zipsCover" size="8" multiple id="zipsCover">
This is populated with about 20 zip codes. When I choose more than one zip code it only saves the first one chosen to the db?
How do I fix this?
couple of thisngs when working with multiple selects;
the select list name must end with [] to create an array of the selections:
<select name="zipsCover[]" size="8" multiple id="zipsCover">
you will need to modify the insert record code to use the php implode function on the zipsCover element.
there will be code similar to:
GetSQLValueString($_POST['zipsCover'], "text")
this will need to be changed to:
GetSQLValueString(implode(", ", $_POST['zipsCover']), "text")
this will convert the array of selections to a comma separated list.
