redirect clientid fails
Thread begun 9/09/2010 7:16 am by mr hankey | Last modified 11/17/2014 8:25 am by Jason Byrnes | 2517 views | 5 replies |
mr hankey
hi,
i have my clients_Detail.php page set to logged in by administators, which should redirect to clients_Detail_user.php for only users logged in. this redirect works however in the address bar where it says "access check" it must be knocking out the recordset to check against the param clientid as it shows nothing on the page. is there a way around this?
many thanks
when you get to the clients_Detail.php successfully, what is the quesrystring variable name?
add that into the redirect code:
WA_Auth_RestrictAccess("clients_Detail.php?quesrystringvarname=.isset($_GET['quesrystringvarname'])?$_GET['quesrystringvarname']:""."");
substitute "quesrystringvarname" with the correct name for the quesrystring variable
georgina_barrett_187762
I have the same problem but when I add that code in Dreamweaver it shows me that there is a coding error
if (!WA_Auth_RulePasses("Admin")){
WA_Auth_RestrictAccess("Client_ID_all.php?ClientID=.isset($_GET['ClientID'])?$_GET['ClientID']:"".""); } ?>
try using this code:
WA_Auth_RestrictAccess("Client_ID_all.php?ClientID=".((isset($_GET['ClientID']))?$_GET['ClientID']:"")."");
perfect thanks
you're welcome.
