DA Drop down references another table - won't reverse reference...
Thread begun 9/08/2010 9:42 pm by ken413883 | Last modified 9/10/2010 2:44 pm by ken413883 | 1857 views | 5 replies |
ken413883
I am building a tool to track some my characters for an MMORPG.
I have a table that contains every spell for every class (spell) containing:
spell_id
spell_name
spell_class_id
spell_level
I also have a table that contains every class:
class_id
class_name
In the DA wizard for the spell table, I used the class table to make a drop down menu for searching (there are no update or insert screens for the spell table, that happens via database insert).
The issue I am having is getting class.class_id to relate to spell.spell_class_id in the original lookup. Right now, the URL shows (||||| just to show where the call is...)
spell_Results.php?S_spell_name=&S_spell_level=&|||||S_spell_class=9|||||&Search.x=36&Search.y=4&Search=Search
I believe (S_spell_class) relates to class.class_id (according to the wizard settings) and I need (S_spell_class) to some how reference spell.spell_class_id...
If I search using any of the other criteria, I get the appropriate result and details pages, and the INNER JOIN statement works just fine for displaying, just not for the original search/query...
Here is the SELECT statement from the results page (which works to display the search results...)
SELECT
spell.spell_class_id,
spell.spell_name,
class.class_name,
spell.spell_level,
class.class_id
FROM
spell
INNER JOIN class ON spell.spell_class_id = class.class_id
Thoughts?
Dave BuchholzBeta Tester
can you post the page that this code is on as this will make tracking down the issue easier
ken413883
Sure Can...
As you can see in the attached files...
Spell_Search.php is the search page
Spell_Results.php is the page with the problem
Spell_Details.php mostly irrelevant (I think) but I included it anyway in case I am wrong.
Note that all 3 pages work fantastically as long as the search doesn't include "class"
In Line 21 of spell_Results.php replace this code
$WADbSearch1->addComparisonFromList("spell_class","S_spell_class","AND","Includes",0);
with this code
$WADbSearch1->addComparisonFromList("spell_class_id","S_spell_class","AND","=",1);
and you should be good to go
this line:
is creating a search criteria using a column named "spell_class".
in your origianl description of the database:
spell_id
spell_name
spell_class_id
spell_level
class_id
class_name
you do not mention a column named "spell_class", nor is there a column named "spell_class" returned from your recordset:
SELECT
spell.spell_name,
class.class_name,
spell.spell_level,
class.class_id
FROM
spell
Inner Join class ON spell.spell_class_id = class.class_id
did you mean to use "class_name" instead?
$WADbSearch1->addComparisonFromList("class_name","S_spell_class","AND","Includes",0);
or spell_class_id?
$WADbSearch1->addComparisonFromList("spell_class_id","S_spell_class","AND","Includes",0);
ken413883
Fixed!!
Dave hit it right on the head! It works!!
Thanks Dave!!!
Jason - you are correct though...I mis-spoke (typed?)
The Class Table only has 2 columns:
Class_id
Class_name
All other tables in the database use Class_id to reference the class table, generally with tablename_class_id.
I hope that made sense. I know what I mean, I'm just having trouble at explaining it...I'm just learning code and databases (been modeling data for a while now...so I know the lingo...just don't know what buttons to push... :-)
