Not Redirecting Properly
Thread begun 9/08/2010 3:29 pm by Martin | Last modified 9/09/2010 9:16 am by Jason Byrnes | 2851 views | 3 replies |
Martin
Greetings,
I have a contact form (created with CSS Form) that I am trying to either forward to a thank you page or to itself and have a "success" message appear. The form works, it validates.
The page is located at: contact_test.php
However, the actual page when tested does not add the ?success to the url parameter. As such the Success message does not display. Also if I change the redirect from a success message to a thank_you.php redirect page, it does not redirect their either.
BUT it does generate e-mails successfully and it does pass all the parameters from the contact form fields!
Any ideas??
Thanks,
Martin
BTW, I have attached the two files in the zip attachment.
change the first to lines:
<?php virtual("/WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php virtual
("/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
to use the require_once function instead of virtual:
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
To prevent Dreamweaver from using the virtual() function for including php files in the future, you should modify your site definition. Change the "Create Links relative to:" option on the local info tab to "Document" instead of using "Site".
Martin
Hi Jason,
Thanks for that info. I have already tried it and it worked perfectly!
I would never have thought to look at the document root settings to determine this problem.
Thanks again!
Martin
you're welcome.
