MM_insert behavior and Captcha
Thread began 9/08/2010 10:36 am by carlene | Last modified 9/08/2010 1:28 pm by Jason Byrnes | 1943 views | 4 replies |
carleneBeta Tester
Hi there,
I'm struggling to integrate your products and am trying to create a custom user registration system. I have created the initial registration form in Security Assist and followed all of the instructions for making the password SAH1 encrypted in your solution recipe videos. securityassist/
I then followed the instructions on for modifying an existing form on the CSS Form Builder support page. I discovered that my registration form DID insert the records into my database - which was great. But here's what's NOT working:
The MM_insert behavior isn't working correctly. When I try a test registration with the same user name instead of telling me that the user name is replicated, I get that the Captcha isn't correct. So somehow this is conflicting. How do I correctly do this? (MM_insert was the fix for a checking for unique user name in the Security Assist videos.)
Also - I would like to apply a Cookie to save the data on the page in case the user gets the Captcha wrong, I don't want them to repeat filling in all of the form field data. How can I retain this data? I have the Cookies Toolkit.
Thanks!
carleneBeta Tester
I'd like to add that the form data IS being correctly inserted into the server. Just need help with the validation and the cookie. (And universal email -- but that's another issue.)
please send a copy of the page so I can look at the code to see what is going wrong.
carleneBeta Tester
there ya go!
ps3_users_Registration.php.zip
your page is missing the Server Validation server behavior.
Between creating the form and applying the insert record behavior, the server validation code got deleted from the page somehow.
you would probably be best off starting the form from scratch.
Create the form using form builder, then test to make sure the validations work. at this point, make a backup of the page before applying the Check New user name and Insert record behaviors.
make sure that code view is not enabled, I have seen server behavior code get overwritten if code view is enabled.
after adding the check new user name and insert record behaviors, double check that the Server validation code is still on place.
