update reminder
Thread begun 9/08/2010 3:07 am by this_is_me | Last modified 9/16/2010 6:20 am by Ray Borduin | 5363 views | 12 replies |
this_is_me
update reminder
I got an update reminder when I opened Dreamweaver today. Going to my download account I found version 1.0.0 there.
Is this a new version without a version number?
Or am I mistaken?
Please enlighten me.
Thank you
Sorry for the confusion. That was just the first time we added Framework builder to memento for the release. There is not an update available yet... I forgot to add the version number, which would have prevented it from showing for people that already have that version.
You can delete or ignore that reminder and I'll add the version number, so it won't confuse more people that haven't opened dreamweaver yet.
superpac250441
Update
When will it be available for download - any idea?
There will be an update to Framework builder very soon, but it will be a relatively minor update since the only bug reported so far is the repeated function declaration error when using it with powerCMS. We should have a fix for that issue out probably in the next couple of weeks. You'll get an eamil and I'll make sure to put the announcement into memento once it is ready.
Steve
Repeat Region error????
What the heck is that?
I'm battling a problem now where my repeat regions do not work properly and I don't use any other extensions other than the Framework.
Steve
""repeated function declaration error"" I searched for Repeat Region errors and see none so this is a different error than I am getting.
I can take a simple page, create a recordset
then echo a value and then apply a repeat region for the value and then a break
<?php do { ?>
<?php echo $row_rs_products['productname']; ?><br />
<?php } while ($row_rs_products = mysql_fetch_assoc($rs_products)); ?>
This creates a repeat region that repeats the correct amount of times BUT repeats the same value X the number of lines rendered.
Only in the framework themed page does this happen and not in the simple test page with the same recordset and repeat region.
Any ideas or others have similar problems?
Does it have that problem when you view the page directly outside of the framework?
The code looks correct. Are you sure that there aren't that many products with the same name? That seems to be the most likely cause is repeated column names in the database and nothing to do with framework or even the code itself not working properly.
What query are you using? Have you tried running that query in your database phpmyadmin and see if there are actually multiple products with the same name. Maybe use a SELECT DISTINCT productname query.
Steve
Hello,
Yes I tested the query and also the repeat region in a minimal page to isolate the query and repeat region.
What I found was that the theme was having a problem with the freeing of the query in the template and then the same named query in the sibling would act wonky (partial success such as the count correct but not able to iterate through the various records).
Yes, you should definitely try to use unique recordset names. Since the page added from framework might as well be added as code to the existing page, variable declarations in general have to be treated as global and shouldn't be re-used.
superpac250441
update reminder
Thanks for the update Ray. DO I presume this will fix the same problem with site sculptor?
