Subtracting stock quantity for more than 1 item
Thread begun 9/08/2010 12:42 am by Badger | Last modified 9/13/2010 7:04 am by Jason Byrnes | 2353 views | 3 replies |
Badger
I'm successfully deleting an eCart's quantity from the field LampInventory on my checkout_success.php based on dlovas275157 solution:
$FinalStack = $eCart1->DisplayInfo("subtractions");
$idProduct = $eCart1->DisplayInfo("ID");
mysql_select_db($database_connChan, $connChan);
$subtractions = mysql_query("UPDATE Lamps SET LampInventory = '$FinalStack' WHERE LampID = '$idProduct'") or die(mysql_error());
How can I make it work for more than just the first item in the cart. Do I need to create an array or loop? If so any examples please.
yes, you need to loop through the cart items.
$eCart1->MoveFirst();
while (!$eCart1->EOF())      {
 $eCart1->MoveNext();
Badger
Thanks Jason, that seems to work perfectly.
Now I'm going to learn why :-)
OK, here's why:
your original code would only ever execute one time for the first item in the cart.
by adding a cart loop:
<do stuff>
the code will execute once for each line item in the cart. the line:
moves the reference to the next line item.
