Dynamic Connections Build GMC4
Thread begun 9/07/2010 3:55 pm by Anna Robinson | Last modified 9/08/2010 7:57 am by anonymous | 1806 views | 3 replies |
Anna Robinson
GMC4 is now available. The only change is the additional session start code, discussed in the GMC3 thread.
Download GMC4.
Serial #: h97Ej-oYnXn-0y9Nd-Vf389
We look forward to your feedback.
anonymous
Anna,
What about the change I discussed with Ray where if you have two domains with exactly the same amount of characters, the code fails until a slight change that Ray had discovered when looking at my file?
I will definitely give this beta a go but without that change, I will still have the same problem.
Thanks,
Brian
That fix was also included in this build... sorry for the confusion. It was actually fixed in another internal build that we didn't send to the beta team, that is probably why Anna overlooked it. Technically that fix was made a while ago, but you guys are just seeing it now.
anonymous
Ray, thanks for the clarification.
Brian
