Problem with access to admin in Power Gallery
Thread begun 9/07/2010 6:16 am by Gabriel Tiviroli | Last modified 9/08/2010 1:20 pm by Jason Byrnes | 2159 views | 3 replies |
Gabriel Tiviroli
Friends, I installed the Power Gallery a few months ago, and at first everything worked well, absolutely everything. The problem is that now when I enter, I get the following error at the login page or login:
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/ipxqpzr/public_html/lunalimos2010/galerias/admin/index.php on line 41
It is strange because it worked well and did not change ever username and password. Then I checked the database and the data is correct.
How I can solve the problem?
download a fresh copy of the admin/index.php page from the Powergallery download center.
looks like a change has been made to your version of the page to cause the error.
On my version, the mysql_num_rows function does not appear at line 41.
Gabriel Tiviroli
The problem persist
I made the change for a fresh copy of admin / index.php and now although the error is no longer the case, neither does the login, i mean, i m enter the correct username and password, I checked the database and all is correct, and yet I can“t enter. What can i do?
sounds like the host may have an issue with session management.
Try downloading the session test page from this post:
showpost.php?p=23826&postcount=2
to test the server session management, if this test fails, you will need to contact the host to have the session management issue resolved.
