Registration Solution Pack and CMS2
Thread begun 9/06/2010 11:56 am by danielsebas | Last modified 9/08/2010 8:37 am by Jason Byrnes | 2189 views | 3 replies |
danielsebas
Hi, I made my site with site sculpture and then apply Power CMS2 and Power gallery now I want to put the registration solution pack, I put it in a separate folder named Registration, and I encrypted password in the solution but the error are shown here:
in my root folder I have a page that's called accounts.php and there I am applying Framework extension and when I call the registration pages it happens something similar to the rel2abs and abs2rel issue, but with the security assist helper.php so should I rename the functions in the helper.php like I did with the rel2abs and abs2rel? should I wrap them in an if function exist? or should I use the security assist help.php file either from the CMS or from the Registration Solution for both solutions? because I noticed they have little differences that affect the users_Profile.php page to work with the send confirmation Email.
Thank you in advance
in the WA_CMS/WA_CMS.php file
find the following line:
require_once( "../WA_SecurityAssist/Helper_PHP.php" );
and comment it out:
//require_once( "../WA_SecurityAssist/Helper_PHP.php" );
danielsebas
Thank you, but wouldn't that affect the CMS? I wrap the functions in the helper, BuildGroups and Mail php pages with an if function_exist condition and everything is working fine.
it will have exactly the same effect on the cms as you wrapping the functions in an if not exist clause.
The security assist files will only effect the live edit mode.
