page size
Thread begun 9/06/2010 9:09 am by mr hankey | Last modified 9/09/2010 7:12 am by mr hankey | 2500 views | 4 replies |
mr hankey
page size
hi,
i have a details page generated by data assist which i have tabs on which contain multiple insert record forms and also displays existing products from recordsets on each page.
it also is linked to google maps.
the page is 254kb and it takes slightly longer to load than the rest of the site. sometimes it is fine but other times it ccan take a while.
is there a way of cutting down the size of file by putting the different forms on the page on other pages and referencing to them? or is it maybe google maps that is slowing it down?
is this size of file too large to be running on the server anyway?
any tips or help is appreciated.
many thanks
anonymous
My guess is that the map is the big file on there. I have several pages throughout several sites with various forms and insert record behaviors and those pages generally are smaller than 20kb.
But 254 seems enormous to me. Maybe you could post the code here for users to look through and see if there is anything else causing such a large page weight.
Best regards,
Brian
mr hankey
thanks brian,
i have around 10 insert records on the page, also i have send email and about 20 recordsets all on the one page.
do you think this is too much for one page to hold?
thanks again
anonymous
I think you should be all good. I have several pages with around 25 to 30 queries going on like this one: www.mix1079fm.com
And there are complex queries happening inside loops too. You should be fine as long as the code is all written correctly. You may run into an issue with the some hosts if all queries were running at the very exact same time due to allowed open connections but the page weight itself shouldn't be an issue.
mr hankey
thanks brian just thought i would check. nice site by the way.
