Parse error: syntax error,
Thread begun 9/05/2010 4:57 am by sunsabbath76401977 | Last modified 9/13/2010 8:34 am by Jason Byrnes | 4535 views | 9 replies |
sunsabbath76401977Beta Tester
Hi
I get this syntax error and I do not know how to correct it...
Parse error: syntax error, unexpected T_IS_NOT_EQUAL in C:\xampp\htdocs\elliots-taxi\contactus.php on line 209
Please see file attached...
This post has been deleted.
The trigger was not written correctly for some reason.
change line 209:
if ((( != "")))     {
if ((isset($_POST["SimpleContact_submit_x"])))     {
Hi Jason
Thanks for the reply.
Every little helps.
Sabby76
You're welcome.
Hi Jason
The same kind of error runs again with latest ammenedments.
Parse error: syntax error, unexpected T_IS_NOT_EQUAL in /homepages/42/d330208130/htdocs/contactus.php on line 489
I've change the line to:
Same error runs
send the most recent copy of your page.
the previous copy has:
<script src="CSSFormBuilder/WA_ServerValidation.js" type="text/javascript"></script>
at line 489, this wont cause a php error.
Back from work...
the code at line 489 is:
there is no synatx error in this code.
one issue i see is that the universal email behavior is on the page 6 times, but the first one is set to redirect to the index page after sending.
the other 5 UE iterations on this page are unnecessary and should be removed.
