Pointer off by a few blocks
Thread begun 9/04/2010 12:51 pm by Roland Rogers | Last modified 9/07/2010 6:54 am by Jason Byrnes | 1842 views | 2 replies |
Roland Rogers
All works well with my use of this extension except that the pointers seem to be consistently off by a couple of blocks when fed through the ProMaps extension. When I use the same data in a regular Google maps window it shows the proper location.
Anyone have any thoughts? The example page is behind a password protected area so I can not show the link. I'll put a couple images up if that helps. The green marker is my ProMaps map the red marker is the usual Google maps image.
anonymous
Roland,
That is really strange. While I haven't personally used this particular extension all that much, I have never seen that happen.
I guess would suggest first double checking the coordinates to make sure everything was entered correctly.
Also, I noticed that there are more items on the map on the right (places of business), which seems odd.
what are the coordinates you are entering.
Can you send a copy of your page and the google_javascript folder in a zip archive so we can try to reproduce the problem to troubleshoot it.
