Remove ribbon from Power Gallery
Thread begun 9/04/2010 12:29 pm by madelectrical386948 | Last modified 9/08/2010 6:23 am by Jason Byrnes | 2485 views | 4 replies |
madelectrical386948
I am working on the ribbon fullsize lightbox. I have copied and started to modify it.
I would really like to have only the main picture and the controls on top to move thru the pics.
I have tried to find out the code how to delete that. What is the easiest way to do that?
Mike
madelectrical386948
I know I can make gallery.js at
options: {
initial: 0,
perPage: 0
Which basically removes the thumb pics. I still have a a div area that is looking for a thumb. How can I get rid of that.
Mike
All of my testing is on a local server. Nothing online yet.
in the galleries/ribbon_fullsize_lightbox/index.php file, the ribon is created by the following code:
<!-- ribbon -->
    <div class="ribbon">
        <div class="prev"></div>
      <div class="thumbs-wrapper">
        <div class="thumbs">
          <div class="thumbs-ribbon-scroller" >
          <?php if(sizeof($gallery['images']) <= 0) { ?>
          <div class="no-images">no images</div>
          <?php } ?>
for($i = 0; $i < sizeof($gallery['images']); $i++) {
            echo
'<img alt="" title="' . $i . '##' . str_replace('"', '\"', $gallery['images'][$i]['title']) . '##' . str_replace('"', '\"', $gallery['images'][$i]['description']) . '"  src="' . $gallery['images'][$i]['thumb']['url'] . '" width="62" height="62" />';
          </div>
                </div>
      </div>
      <div class="next"></div>
    </div>
removing that code will remove the ribon.
NOTE:
This is not a supported modification.
Removing the ribbon may break other functionality.
madelectrical386948
Thx, I will give that a try and see how robust it is.
I will let you know.
Mike
you're welcome.
