Recover Designs?
Thread begun 9/02/2010 5:13 pm by MikeH | Last modified 9/03/2010 11:53 am by Jason Byrnes | 2020 views | 3 replies |
MikeH
Recover Designs?
Hi
Right backed up my PC and started from scratch with a new windos 7 install.
Now without realising I did not export my CSS Sculptor designs can these be recovered or is it the dreaded start again scenario?
Mike
PS in shared/webassist/sculptor/ in my backup I do have the files in there bu the new install does not want to know them.
The designs are stored in the in the configuration/shared/webassist/CSSSculptor/DesignTypes folder.
you should be able to copy your custom designs from there to the new configuration folder to retrieve them
make sure Dreamweaver is closed when you do this. and also delete the cache file when you are done.
MikeH
Thanks Jason
Worked a treat. I did try it last night and not for anything would it work but today tried it again after reading this and it worked. Thank you once again for your help.
Mike
great glad to hear it is working.
