Recordset Errors
Thread begun 9/02/2010 9:46 am by gpaul | Last modified 9/09/2010 6:53 am by gpaul | 7089 views | 3 replies |
gpaul
Recordset Errors
When creating new page through the Data Assist Wizard, there is a recordset that is being created that full of variable errors. The error message is
Paramimage is an invalid variable name; it does not appear in the SQL
Missing type for variable:Paramimage
ParamSessionimage is an invalid variable name; it does not appear in the SQL
Missing type for variable:ParamSessionimage
Missing Run-Time Value for variable:Paramimage_id
Missing Run-Time Value for variable:Paramimage_id2
Missing Run-Time Value for variable:ParamSessionimage_id
Within the code there is no Paramimage or ParamSessionimage. There are Paramimage_id,Paramimage_id2, ParamSessionimage_id, however they do not have runtime values.
I tried to delete the Paramimage and ParamSessionimage, but they simply re-appear.
I tried to take the runtime values from theParamimage and ParamSessionimage and apply them to Paramimage_id,Paramimage_id2, ParamSessionimage_id, but it returns no records on a test, and the 3 invalid variables re-appear again upon reopening the recordset.
Below is the corresponding code for the recordset.
$Paramimage_id_WADAimages = "-1";
if (isset($_GET['image_id'])) {
$Paramimage_id_WADAimages = (get_magic_quotes_gpc()) ? $_GET['image_id'] : addslashes($_GET['image_id']);
$Paramimage_id2_WADAimages = "-1";
$Paramimage_id2_WADAimages = (get_magic_quotes_gpc()) ? $_GET['image_id'] : addslashes($_GET['image_id']);
$ParamSessionimage_id_WADAimages = "-1";
if (isset($_SESSION['WADA_Insert_images'])) {
$ParamSessionimage_id_WADAimages = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_images'] : addslashes($_SESSION['WADA_Insert_images']);
mysql_select_db($database_jfinlocal, $jfinlocal);
$query_WADAimages = sprintf("SELECT image_id, caption, where_taken, description, file_name, image_file, submitted FROM images WHERE image_id = %s OR ( -1= %s AND image_id= %s)", GetSQLValueString($Paramimage_id_WADAimages, "int"),GetSQLValueString($Paramimage_id2_WADAimages, "int"),GetSQLValueString($ParamSessionimage_id_WADAimages, "int"));
$WADAimages = mysql_query($query_WADAimages, $jfinlocal) or die(mysql_error());
$row_WADAimages = mysql_fetch_assoc($WADAimages);
$totalRows_WADAimages = mysql_num_rows($WADAimages);?>
This is the SQL
WHERE _taken, description, file_name, image_file, submitted FROM images WHERE image_id = Paramimage_id OR ( -1= Paramimage_id2 AND image_id= ParamSessionimage_id)
Also, one of my columns is where_taken, which is being transformed in the recordset into WHERE _taken, which also creates an error, but it re-appears after I correct it.
Anyone be able to help me straighten this out?
Thank you.
Gary
tom92909Beta Tester
I assume that you'll be locating each record in the following manner...
myimage_detail.php?image_id=32
Right?
If that's the case and you're not using any specific SEARCH criteria on your "results" page, then you can simply remove all of the
Paramimage_id
Paramimage_id2
From your Recordset - Variables section in Dreamweaver.
All that really matters is
Paramimage = $_GET['image_id']
The SEARCH (form) on your details page is controlled by the additional variable parameters that appear to be producing your errors.
Something like that should resolve the errors I think.
This is a problem with Dreamweaver / DataAssist and the underscore naming convention.
The issue is this:
In DataAssist, when a parameter is created, it uses the name of the column to ensure that the parameter name is unique
the variable name for the parameter is written as:
$Param<columnName>_<RecordsetName>
so for the image_id column the parameter code is created as:
When Dreamweaver inspects the code, it interprates everything after the first underscore as the recordset name.
so Dreamweaver sees:
as:
rparameter name:
$Paramimage
recordset name:
id_WADAimages
thwe work around is to change the names of the parameters in the code. for example find:
and change it to:
$Paramimageid_WADAimage
gpaul
Thank you
I would like to apologize for not responding sooner and thank you for your help.
Tom
You were correct
<<I assume that you'll be locating each record in the following manner...
myimage_detail.php?image_id=32>>
However
$query_WADAimages = sprintf("SELECT image_id, caption, where_taken, description, file_name, image_file, submitted FROM images WHERE image_id = %s"), GetSQLValueString($ParamSessionimage_id_WADAimages,"int"));
produced a Parse error, saying an unexpected , (comma) was encountered. I tried a few variations however could not shake the errors.
I was finally able to get things to work (almost), I created a new set of files, I still encountered the same creation of the Paraimage variables, but was able to work around them.
It is perplexing and frustrating that these are created, even more so that Dreamweaver rejects them as incorrect.
Either way, I got a good education in WA and almost have it working the way I want.
Jason
Thanks for that information, I will use camelCase naming when using WA. I guess I should be happy I did not name that column select_where_from, dreamweaver might have thrown a major hissy fit...
Thanks again for your help.
Gary
