Progress Bar Problem
Thread begun 9/02/2010 7:37 am by vincent.rycx336448 | Last modified 9/02/2010 11:16 am by Jason Byrnes | 4812 views | 11 replies |
vincent.rycx336448
When uploading files from my website to my server, the progress bar works fine with a hosting provider and not with another. It does not work locally either.
Here is the code on my page.
<div id="form1_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('form1', 'form1_ProgressMessageWrapper', WADFP_Theme_Options['ExtendingWheel:Pacifica']);
</script>
<div id="form1_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="webassist/progress_bar/images/pacifica-wheel.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
Thanks for the help.
hard to say what the problem is without seeing it.
can you post a link where it does not work so I can take a look at the page in context.
vincent.rycx336448
Test_1.php
By the way, it does not work in Opera on any server.
tom92909Beta Tester
I just attempted an testfile upload, and I can confirm that the progress bar did not work in Google Chrome either.
neither the script file:
jquery-blockui-formprocessing.js
nor the progress bar image file:
can be found on the server.
make sure that these files have been uploaded.
vincent.rycx336448
I removed the Digital File Pro extension to replace it with Universal Email
did you delete the Dreamweaver cache file after removing digital file pro?
the script is referencing the Digital File pro script file:
<script src="WA_DigitalFilePro/jquery-blockui-formprocessing.js" type="text/javascript"></script>
vincent.rycx336448
WA_DigitalFilePro...mprocessing.js
Those where present on server 1, where the progress bar works.
Those are not on server 2. (arhezo.info)
yes, that is true.
they will need to be uploaded to the second server for the progress bar to work.
vincent.rycx336448
"the script is referencing the Digital File pro script file:
<script src="WA_DigitalFilePro/jquery-blockui-formprocessing.js" type="text/javascript"></script> "
That is the explanation.
Thank you very much Jason.
