Power Store I need to change weight to oz.
Thread begun 9/01/2010 9:14 am by drewgss371883 | Last modified 3/16/2011 11:40 am by Jason Byrnes | 3972 views | 6 replies |
drewgss371883
I need to find out how to change the unit of measure on a product to oz. from lb.
on the confirm and pp_confirm pages, find the following line:
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "LBS";
and change it to:
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "OZ";
it should be found 3 times on each page.
drewgss371883
Shipping Weight
Thanks sorry it has taken this long to get back to this.
I found two places in each of the documents.
Now does this mean that the shipping calculations will work properly, and should I change the "admin/Products_Update.php" to read Weight in lbs: to Weight in ozs: so it does not confuse my client.
drewgss371883
Weight change to oz
I did go back and found the third place in both documents and changed them.
First time the search didn't find it because the OZ was oz.
yes, the shipping calculations should now be suing Ounces instead of Pounds.
any place that the weight is referenced as ponds should be changed to ounces to prevent confusion.
drewgss371883
I am updating to Power Store 4 and need to change the weights from LBS to OZ and the directions above do not work.
if you are using 4.5, you can change the wight units in the admin settings panel now.
